installing 30# injectors over lunch
BlackVert
5,589
9
98
Bethesda, MD
hopefully it will go without incident. i'll look crazy out in my parking lot at work with the hood up, but they are kinda used to me like that by now.
the nice thing about these injectors is that they have been flow tested (4 at 30.1 lbs/hr, 1 at 30.2, and 3 at 30.0), so i know just what value to enter in my calibration, so the tuning should be very straightforward for this. it will also allow me to make that parameter a constant. it's always better if there is one less variable in the equation. i'm going to set my cal at 30.1 and then i can forget that part of the tune. :nice:
i was considering the option of getting a matched set, where they all flow exactly the same amount, but that was almost twice as expensive, and this will be fine for my purposes.
wish me luck ... if things go as planned, i will have some 42# injectors up for grabs today. if anyone is interested in them, pm me
aborted!
it's cold and cloudy, i need to take off the intake tubing, and it has 12pt bolts and i only brought 6pt sockets with me. had i actually looked at it BEFORE collecting what i thought i needed for the job, then i would have known to bring the 12pt socketes and i might have decided to brave the cold. :nonono:
sigh. maybe tomorrow.
How are 30s gonna support a custom cammed, AFR 205 headed 410?
Adam
i knew someone would ask that ...
i drive like the old man i am.
my typhoon intake is a serious restriction.
my research has indicated that 30# injectors are good for up to 500 horses.
i have 3.27 gears. 4000 rpm in 2nd is like 60 mph, in 3rd it is like 100, and in 4th, it is about 140. i don't need to go past 4000 to go as fast as i want.
under heavy throttle, my AOD shifts 1-2 around 3300 with all kinds of whel spin, 2-3 at about 3500 and 3-4 closer to 3000. believe me, by then, i am going plenty fast enough for my purposes.
i have not yet run it past 4000 rpm and doubt i will ever take it past 4500 rpm. that is just the way i am.
lastly, if i hear pinging, i pull out. should that happen and i determine that the injectors are not keeping up, i'll get 42s again. it is a 30 minute swap.
Seriously, you don't need all that engine. We should swap engines. My 400hp 347 is all the engine you will ever need. Runs great, great street manners, no metal in the oil pan ever.
Kurt
Kurt
please feel free to come to bethesda and swap them. just bring your hoist and a couple grand.
or if yours is a convertible, then we can just switch cars.
seriously
ARGGGGGGH! aborted again. :bang:
i brought my 12pt sockets in today, and wouldn't you know, none of them fit?
so i go to the home depot and all they had in 12pts were too big too. :big sigh:
so its' off to sears. they have plenty 12pt sockets and i am sure one is right, but they are locked in a cabinet and i can not find anyone to help me for like 15 minutes. finally the guy comes around and i ask him if he would just go out with me and a couple of them to see which one fits.
he says no. i wanted to punch him.
so i grab 4 and go stand in line to buy them just to see which one fits and return the others.
there are 3 people in line in front of me. another 10 minutes ticks by. by now i'm really pissed.
i finally get back to the car ... none of them fit. of course.
back inside, grab 3 more, do the return/purchase. more people in line, 10 more minutes. tick tick tick ...
YAY! the 5/16" 12pt socket fits!!!!! :banana: it took 5 minutes to do the 2nd return.
so it took me an hour to find the one freaking socket that fits. :bang:
i'll probably be just getting ready to start tomorrow and a tree will fall on the car or something
So is swapping injectors really that easy? I've never tried it before.
I'll be having an AFR 185 headed 11:1 c/r 347 built this summer, so I guess 30 pounders are the standard fare for such an engine? I'm about in the same boat as you as far as revving goes, however I'd probably take it closer to 5500-6000 from time to time. :)
heck fire, given what you have done with your current motor, i would not be surprised if you could milk more like 550 at the wheels with mine.
i was thinking i'd sell the 42s, maybe i'll hold on to them for a while first
:cheers:
If I had a couple grand and some vacation time, I would be driving up there with my engine hoist. Unfortunately I'm broke at the moment. Maybe later on down the road if you still have that car with that engine. I've almost got 500 to the wheels on my current engine. A few more tweaks and I should be there.
Kurt
I will compare to my industry. I'm doing high voltage design right now. You never install transmission conductor such that the source can supply more power then the conductor can carry. If this happens the conductor burns down, and repairs cost millions. You always rate the conductor to carry more current then the highest output of the source, so that the conductor is NOT the limiting factor. Make sense?
So why make your fuel system the limiting factor? It should be the heads or intake.
$0.02.
Adam
