I'm going to be performing an interior swap (it has been on my wish list for the last two years).
My current interior is gray/black, rattles like a snake, and is broken everywhere (pictures later).
I've spent a day at the junk yard and while doing it I started running into a bunch of questions but kept pulling parts anyways.
Will the driver and passenger seats bolt right into my 95 from the 99-04?
Is the electric motor harness connector different between the two years, if so how can I adapt the 99-04 to work with my 95 factory harness
Would the airbags from the 99-04 be plug and play replacements? (I'm just amazed I found them intact)
What would be the closets and best type of paint to use to redye certain parts (03/04 black on black color scheme)?
Is there anything I should consider doing while I have the interior out, replacements, easy cool mods, whatever?
How do I remove the interior door handles?
Some awesome things to note*
*pictures of my current interior will be uploaded later in a new post
*in the same post will be some of the new replacement parts so you all can enjoy my junkyard fines
*I bought the entire interior for 150, amazing, I know
I should also mention I remember reading two threads about interior improvements, one involved using a rubberized spray on the back of the stereo bezel to reduce vibration noise and another very detailed thread of dyeing of the interior including best ways to clean interior pieces. If you're aware of these threads, please link them!
Edit: Davis' thread was one: http://www.stangnet.com/mustang-for...dashboard-how-to-warning-tons-of-pics.746918/
here's the other; http://www.svtperformance.com/forums/how-230/689831-dash-radio-bezel-vents-rattle-fix.html
Here's one about dash removal and heater core replacement: http://poisnus.com/files/heater_core_replacement.html#_Toc193016800
I also need to swap the wiring harnesses for the door locks and windows since somewhere along the way some wires must've fused and causes my door lock buttons to not work but instead turn on the dash lights.
and a side note, for those of you who remembered, my car is still in the shop for the transmission swap so right now I can't really check any direct replacements and fitment till I get the car back.
Thanks, Jordan
Thanks, Jordan
