  • 1994 - 1995 Specific Tech
is an e303 cam too small for a 94 Cobra?
  • Thread starter Thread starter greenstang1313
  • Start date Start date Aug 6, 2006
G
greenstang1313
158
Chelmsford, MA
Aug 6, 2006
  • Aug 6, 2006
I have an E-cam awaiting install for my 94 Cobra and some people have said its not much bigger than the stock cobra cam and I should upgrade to the F or B cam.
I dont race at the track and I dont normally bring the car up past 4000rpms more than a few times a day so I want a cam that will give me big gains in the lower RPMs.
Should I stick with E, or upgrade to B or F? and WHY
legalize420
1,541
South Florida
Aug 6, 2006
  • Aug 6, 2006
stick with the e303, there are a few people on here running the same combo.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Aug 6, 2006
  • Aug 6, 2006
I would stick with it unless youre doing other power upgrades..you should be fine.
RC
G
greenstang1313
158
Chelmsford, MA
Aug 6, 2006
  • Aug 6, 2006
thanks guys. I probalby will stick with the e-cam.
SVTCobra306
170
Ft. Bragg, NC
Aug 6, 2006
  • Aug 6, 2006
Hope your 'puter likes it. The 110 lobe sep and the newer computers don't play well with each other.
The stock Cobra cam was only .485 lift, had less than 270 duration, and was like a 118 lobe seb.
You really want to stick with a "blower cam" lobe sep with these cars, 112 or 114.
A lot of guys get along well with 2031 cams and steeda #19 cams. the 2040, E cam, and TFS 1 cam are hit or miss on what surging and idling problems you may have.
bimmertech
1,123
merriam, ks
Aug 6, 2006
  • Aug 6, 2006
i agree to an extent. it seems that the cobra guys have a bit less difficulty in surging and idling problems. i run a tfs1 with stock ecm and have no idle issues at all--95 cobra.
as for cam selection i have this to say:
there is no such thing as a cam too big---just not enough motor.
H
hookups333
154
Jax Florida
Aug 6, 2006
  • Aug 6, 2006
I have an e cam and i like it. It makes good power for 2k and up.
JJ95GTID
1,141
Phoenix, AZ
Aug 6, 2006
  • Aug 6, 2006
Don't forget that the FRPP cams valve lift values are for a 1.6:1 ratio rocker. Your Cobra should have 1.7:1 ratio rockers stock. So, the valve lift is actually higher.
BadAndy
766
Ohio
Aug 6, 2006
  • Aug 6, 2006
I like the tfs stage-1 cam -I was thinking alot of people with the E cam had idle problems
enyawix
507
Aug 7, 2006
#10
  • Aug 7, 2006
  • #10
BIG cams have intake exhaust overlap . Not good for blower setups
Screamin Demons Worth It N/A?
  • Blackout67
  • Oct 20, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 20, 2025
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
