is it really this slow?
  • Thread starter Thread starter 331strokerlx
  • Start date Start date Aug 21, 2009
  • 3
  • 4
  • 5
  • 6
First Prev 2 of 6 Next Last
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Aug 22, 2009
#21
  • Aug 22, 2009
  • #21
im running 1.2 secs faster than you with my lil 281 4.6. usually a stockish 5liter will go 13s easily. somemthing is wrong with your car
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Aug 22, 2009
#22
  • Aug 22, 2009
  • #22
This is why I don't buy other people's projects. Well, actually I did once, my old Z28 Camaro, I learned hard that way. Sorry man but you are going to have to fix what this guy didn't do right.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Aug 22, 2009
#23
  • Aug 22, 2009
  • #23
I say fix that tranny before looking into the motor any... Even a 302 with those parts should run in the 12s or 13s... my opinion.
331strokerlx
117
Columbus Ohio
Aug 22, 2009
#24
  • Aug 22, 2009
  • #24
Since the tranny is going south I think I will save up and do a 5 speed swap. Parts wise how much should it cost. is it something that can be done in a driveway
90mustangGT
2,773
17
89
Dallas, GA
Aug 22, 2009
#25
  • Aug 22, 2009
  • #25
How about taking it to a professional technician. Might charge you a dianostic charge but that's damn better than the extra cost and headache of throwing parts. I know, I know, every tom dick and harry is a tech but there is a far difference between someone who works on them on the side and someone who does it for a living where they have to get it right the first time or they wouldn't have a job.
68stang351
850
9
39
Savoy TX
Aug 23, 2009
#26
  • Aug 23, 2009
  • #26
LaserSVT said:
I dont know what size red injectors are but I am sure someone will chime in.
CRASH7772
401
NH
Aug 23, 2009
#27
  • Aug 23, 2009
  • #27
I was running 14.6's@mid 96's mph stock with my 87GT 5 speed with 2.73's and 2.2 60' times. After a few small bolt-ons (Kirban FPR, A/C delete, Mac underdrive pullies, 140 Power Master Alt, Jacobs ignition, Mac 70mm TB/EGR, K&N filter, and Flex-a-lite electric fan, 2 1/4" Dyno-Max cat back) I was making 225 rwhp and 298 rwtq on the dyno and running high 13's. If the trans has issues get it looked at but if you think it's ok try to find a dyno and see if the motor is making the power it should be.
CRASH7772
401
NH
Aug 23, 2009
#28
  • Aug 23, 2009
  • #28
I would look for a low mileage used TKO setup. I know myself and my cousin both found some decent setups for under 2k. Also I noticed that you don't have your coolant lines (on throttle body) or your line from the valve covers to your throttle body. From what I have heard this isn't necessarily a good thing. Kinda makes you wonder what else has been bypassed or skipped.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Aug 23, 2009
#29
  • Aug 23, 2009
  • #29
For what its going to cost you to do a 5-speed swap, not to mention all of the time and effort involved in the conversion, you could build up one mean AOD with converter. It'll be both faster and more consistent than any 5-speed swap you're thinking of.
2000GTdriver
47
Mile High City, Colorado
Aug 23, 2009
#30
  • Aug 23, 2009
  • #30
I would find out exactly what you have in the engine first. Pull a head off and measure bore and stroke to see if it is really a 331. While the head is off identify what brand and size it is. Back when I was younger and dumber I bought a used 69 Camaro the owner claimed had a high performance 327 in it. After painfully sorting through many hack-job issues I finally determined it was really a 307 with some used 327 heads bolted on. So check to make sure you really have a stroker, and since heads a such a critical part of a build you need to know what you got. That could save you lots of money and headaches later on.
331strokerlx
117
Columbus Ohio
Aug 23, 2009
#31
  • Aug 23, 2009
  • #31
Thanks for all the help. After talking it over with my stepdad I am going to go with another aod to save time and money. what size stall would you recomend. The car will be a daily driver but will go down the track once a month. What do those lines that aren't hooked up do
331strokerlx
117
Columbus Ohio
Aug 23, 2009
#32
  • Aug 23, 2009
  • #32
i looked at the fuel pressure gauge and it shows 28psi at idle and it drops to 20 when i move the throttle. Is that normal
90mustangGT
2,773
17
89
Dallas, GA
Aug 23, 2009
#33
  • Aug 23, 2009
  • #33
no, that is way low. It should go the other way anyways. should be 39 at idle and about 45 at throttle.
I bet you have a weak pump or restricted line. How old is the fuel filter.
331strokerlx
117
Columbus Ohio
Aug 23, 2009
#34
  • Aug 23, 2009
  • #34
I dont know how old the filter is I haven't changed it since I got the car and I don't know when the previous owner changed it. As soon as I get paid I will change it. Is it difficult to change?
mc0311grunt
86
Los Angeles
Aug 23, 2009
#35
  • Aug 23, 2009
  • #35
fuel filter can be changed in about 15 minutes. Located in front of fuel tank. Fuel filters cost about $10.
mc0311grunt
86
Los Angeles
Aug 23, 2009
#36
  • Aug 23, 2009
  • #36
Yeah with that setup you should be in the low 13s. I have a stock 86 block, e7 heads, bbk shortys, and ford countour fans and I hit 14.02@95 at California Speedway. Something is wrong. Run a compression test to make sure you got good comepression.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Aug 23, 2009
#37
  • Aug 23, 2009
  • #37
Put in the tranny and see what happens. As for the stall, that is the trick of the auto cars, choosing the right one for your combo! A T5 could be swapped for $10000, but probably wont last forever behind that motor.
90mustangGT
2,773
17
89
Dallas, GA
Aug 23, 2009
#38
  • Aug 23, 2009
  • #38
did you guys not read this? I'm suprised it runs at all. It must be one hell of a strong engine to even be drivable with this condition.
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Aug 23, 2009
#39
  • Aug 23, 2009
  • #39
"Put in the tranny and see what happens. As for the stall, that is the trick of the auto cars, choosing the right one for your combo! A T5 could be swapped for $10000, but probably wont last forever behind that motor."
I assume he meant $1000, but as everyone else has said, swap the fuel filter, get rid of whatever the hell happened to that shifter, and give it another go before getting into a trans swap
331strokerlx
117
Columbus Ohio
Aug 23, 2009
#40
  • Aug 23, 2009
  • #40
If I were to get the transmission that's in it rebuilt how much do you guys think that should run me. My plans for the car is a dd with some track time. When i am driving it and the car downshifts when i floor it the car feels like it has a ton of power but sometimes hesitates around 3k rpm. I have about had it with the motor is a 4.6 alot to convert
  • 3
  • 4
  • 5
  • 6
Aod to t5 swap will it live?
  • 87slow.0
  • Nov 5, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2024
87slow.0
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
J
Engine LOSS OF POWER AT 4,000 RPM.
  • Jarhead67
  • Nov 17, 2024
3K
Fox 5.0 Mustang Tech Jan 25, 2025
Jarhead67
J
Intended Headers and Trans, questions about fitment
  • from6to8
  • Aug 6, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
from6to8
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
