I'm going to try to start mny car today. Here is my combo, eagle 331 w/ je pistions afr 185 heads, ed c cam with a .605", .598" lift 112 lobe separation and 228, 234 duration, 75mm throttle body, 80mm pmas, 30 lb injectors, rpm2 intake ect......
My few questions are the firing order that I want is 1-3-7-2-6-5-4-8 correct?
What should I set my fuel pressure to? Do this with the vacuum line disconnected then connect it?
THis is the stock tune right now and I know about the problems i'm going to have with my cam. I need to break the clutch in first then i'm going to get a dyno tune. Anything I need to know about running the stock tune, Is it safe?
And Lastly what should I set my timing to once this fires up?
Thanks everyone I'll post some pics later!
) while I inspected for leaks and any odd sounds and to allow the new parts to sort of get to know each other and remove any grunge, engine lube etc. I then changed the oil. I used straight 30w Valvoline oil. After the oil change, I took the car out did about 10 (can't remember exactly) 2nd an 3rd gear pulls to about 3000 rpm to 3500 rpm and let the car come down the rpm range on its own. This was to load and set the piston rings. Afer that I just drove around for a while just gloating. Then I took it back to the garage and changed the oil again (10w-40 Valvoline) - may not be necessary but I did it anyway. Some say baby the car for about 1k miles and others say drive it like you stole it. I did a little of both initially and then I just said to the hell with it and began driving it like I stole it.
I drove the car for just over a year and less than a month ago I switch to synthetic after 2k miles (15w-50 summer 10w-30 winter). Oh yeah, this is not my DD so it took awhile to get the 2k miles on her.
Just One Man's Opinion and who's car is still intack with no issues.
