little help
  • Thread starter Thread starter stryker02GT
  • Start date Start date Mar 1, 2004
stryker02GT
44
Albuquerque, NM
Mar 1, 2004
  • Mar 1, 2004
im not sure if i have posted this question on here before or not, but even if i did, i cant remember the response. here is my mods list, i am just wondering what i should expect on a Dyno run. if anyone of you have this setup or something similar to it, and have had your car dyno'ed, that would be stellar if you would tell me your dyno numbers. i dont want to be disappointed when the time comes for me to get it dyno'ed. thanks to all that reply.
here is my list:
~331 stroker
JE pistons
Eagle forged steel crank and rods
10:1 compression
~Edelbrock Performer RPM aluminum heads w/2.02 exhaust valves
~Edelbrock Performer RPM upper and lower intake plenum
~Comp Cam
.565 lift 224/232 split duration @.050
~BBK 75mm throttle body & EGR spacer
~BBK Cold Air Induction
~BBK Fuel Pressure Regulator
~FMS 24# injectors
~MSD 8.5mm wires
~MSD distributor
~MSD coil
~MAC Pro-chamber off road H-pipe
~MAC 1-5/8" headers
~Magnaflow 2.5"-3" catback system
~Centerforce Dual Friction Clutch
~FMS 3.73 gears
~Pro 5.0 shifter
stryker02GT
44
Albuquerque, NM
Mar 28, 2004
  • Mar 28, 2004
is no one going to help me out on this? surely there is someone out there that has an idea on what i should expect
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
F
carb vs cam help needed
  • forango
  • May 2, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2025
forango
F
