im not sure if i have posted this question on here before or not, but even if i did, i cant remember the response. here is my mods list, i am just wondering what i should expect on a Dyno run. if anyone of you have this setup or something similar to it, and have had your car dyno'ed, that would be stellar if you would tell me your dyno numbers. i dont want to be disappointed when the time comes for me to get it dyno'ed. thanks to all that reply.
here is my list:
~331 stroker
JE pistons
Eagle forged steel crank and rods
10:1 compression
~Edelbrock Performer RPM aluminum heads w/2.02 exhaust valves
~Edelbrock Performer RPM upper and lower intake plenum
~Comp Cam
.565 lift 224/232 split duration @.050
~BBK 75mm throttle body & EGR spacer
~BBK Cold Air Induction
~BBK Fuel Pressure Regulator
~FMS 24# injectors
~MSD 8.5mm wires
~MSD distributor
~MSD coil
~MAC Pro-chamber off road H-pipe
~MAC 1-5/8" headers
~Magnaflow 2.5"-3" catback system
~Centerforce Dual Friction Clutch
~FMS 3.73 gears
~Pro 5.0 shifter
here is my list:
~331 stroker
JE pistons
10:1 compression
~Comp Cam
~FMS 24# injectors
~MSD 8.5mm wires
~MSD distributor
~MSD coil
~MAC 1-5/8" headers
~FMS 3.73 gears
~Pro 5.0 shifter
