These all sound in the ball park. I recall a general spec of 80 ft.-lbs., maybe up to 90 or 100 ft.-lbs., for aluminum wheels, and around 100-120 ft.-lbs. for steel wheels. 90 ought to be safe. I'd follow the pattern around at least twice at that torque, or until they no longer move after going through the rest of them.
Torqueing in stages would be a good idea also - go around and get them all finger tight, or "light-wrench" tight. Then go around and torque them all to 50 ft.-lbs., then go around again at 80 or 90 ft.-lbs., and follow them around at that same torque once more. If none of them moved further, you're done. If some of them (more than just 1) move some more, follow them around once more to make sure they're all up to the limit.
All that said...I frequently tighten them without a torque wrench...but it's a good idea that I SHOULD follow. Regardless, I give them several passes, cause tighten the others frequently effectively loosens the earlier ones.
