maf-engine-injector help
  • Thread starter Thread starter olymaster
  • Start date Start date May 15, 2005
olymaster
179
columbus ga
May 15, 2005
  • May 15, 2005
i am performing an engine swap in my 91 gt vert
its a 302 with edlebrock heads, edlebrock intake,ford racing headers,24lb injectors and such rated at 355 hp natural
the custom garge thats doing the work was going to put a pro-m maf on it but wont now that they are out of buisness
he said they will but a tunable superchip custom in it and use the stock maf. im confused because the stock maf is for 19 lb injectors. will the stock maf work with a tuned chip or should i replace the maf with a 24 lb maf
also when installing a maf is it like plug and play or do i have to get that tuned too.?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
May 15, 2005
  • May 15, 2005
A new MAF calibrated for your 24lb injectors will be "plug and play"...I would do that. Get the correct calibrated MAF...
D
Daggar
3,902
  • May 15, 2005
What he says about the chip is correct. The computer can be told how to deal with the new injectors and will be more precise than a calibrated meter. the problem is with the stock meter size. It will end up being a restriction. If you're going to have a custom chip burned to accomodate the meter then I would consider finding a larger meter instead of wasting hard earned cash on a chip and programming for the stock one.
Edit: A "plug-n-play" calibrated meter will be the most cost effective option though.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
help me understand calibrated maf sensors and injectors
  • stackz
  • Sep 21, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
AeroCoupe
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
