Technical Mass Air /REcalculator ???'s
So i'm looking through the Brothers Perf. mag today and run across Diablo-Sport MAFia Mass Air Recalibrator. $149.00 ...it's details say
"...allows the customer among other things to use their factory MAF sensor when changering to bigger injectors for high HP or s/c app's. The MAFia is an in'line plug-and-play that allows you to control ...the maf. eliminates the need for a special cal'd maf for bigger injectors. ..***it does this by recalibrating the signal output from your MAF. ...works w. 4 and 6 wire maf's, User selectable 8 settings for diff HP levels (stock to gangster level) <haha but that's in there too. ....led indicator of Maf Voltage Status shows if maf is pegging"
that is actuall me shortening it up a lil ha! .... but i wanted you to have all the info i'm getting.
My question to you more knowledgeable...
-Have you heard of, used, or seen in action ...and thoughts
-Is this a good thing? ...8 PRESETS (for hp level) good or bad thing? or is it presets for diff lb inj's
-Is this actually a good solution to recal or getting a new maf everytime you one up your car???
and...if is recalibration of a maf for bigger injectors just include upping the output voltage to the ecm from what the maff reads its flowing... couldn't someone with basic to moderate electronics wiring skill wire up and make your own one of these?????
if i'm asking to much...tell me, i just really want to understand this deeper..or direct me to more sites.... i'm interested in what you need for a maf and how it works (detailed altogether)
