maxing out stock 19's? upgrading?
  • Thread starter Thread starter 98COBRA281
  • Start date Start date Jan 19, 2009
First Prev 2 of 2
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Jan 19, 2009
#21
  • Jan 19, 2009
  • #21
i wounder if its loosing a few ponies up top because its leaning out
CobraRed_96_GT
1,421
UCSD/La Jolla
Jan 19, 2009
#22
  • Jan 19, 2009
  • #22
It might be gaining them unsafely as well, usually people add timing or lean out for power, although if you're much too lean you'll lose power.
98COBRA281
1,348
30
59
Jan 19, 2009
#23
  • Jan 19, 2009
  • #23
very true,
i wish i could get some 24's by saturday, i probably going to have to wait an extra week
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 19, 2009
#24
  • Jan 19, 2009
  • #24
98COBRA281 said:
well as most of you know my car just put down 310rwhp on the base tune, and my tuner told me that the 19lb injectors are prolly going to be maxed out, he told me to get 30's and a lighting MAF? befor i go back to him, i dont think i realy need 30's, wont 24's be more then enough with the stock MAF?
Do you ever plan on adding some sort of power adder like forced induction, or nitrous? If so, why not go with a set of 30's or even 42's? They can be tuned just as easily as a set of 19's and if or when later on you do ever need additional fuel they'll be up to the task. A set of 24's won't be good for any more than about 330-350rwhp and you'll make more than that at this point with any power adder.
98COBRA281
1,348
30
59
Jan 19, 2009
#25
  • Jan 19, 2009
  • #25
i have considered a small shot of nitrous, but not to sure just yet, so 30's would be a better bet?
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 19, 2009
#26
  • Jan 19, 2009
  • #26
30's with nitrous is probably safe for up to about 360rwhp....so as long as you keep it under a 50-shot you'll be fine. Anything more than that and you'll probably start getting back up into the 80%-90% duty cycle range...and you don't want that. I'd go with 42's. Remember, when adding nitrous, or forced induction to the mix, the BSFC rate changes and an injector that would normally feed 350hp in N/A trim won't cut it when trying to keep up with a power adder. Bigger is always in the case, better. A set of 42's won't affect your idle or drivability what so ever by comparison and they cost nearly the same as 30's...so for my money, I'd go with them.
Too much injector can always be tuned around, but too little can't.
98COBRA281
1,348
30
59
Jan 20, 2009
#27
  • Jan 20, 2009
  • #27
well i found a cheap set of 24 's on ebay, so i bought them, and there coming up from miami, so i should have them by friday.
mustangman9812
661
Mars Hill, NC
Jan 20, 2009
#28
  • Jan 20, 2009
  • #28
Sweet Man! I cant wait to see final numbers!
Slow35th
37
#29
  • Feb 6, 2009
  • #29
any final numbers?
98COBRA281
1,348
30
59
Feb 6, 2009
#30
  • Feb 6, 2009
  • #30
Slow35th said:
any final numbers?
not yet, my tuners computer is on back order, and told me he will have it by the 26th
so right now im just running a base tune he gave me so i could run the 24's, and not be lean..........
ill be sure to post up the final numbers!!!
First Prev 2 of 2
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
2K
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
9
96 mustang gt
  • 96projectgt
  • May 2, 2025
  • 2 3
2K
1996 - 2004 SN95 Mustang -General/Talk- May 15, 2025
96projectgt
9
