Been trying to figure out a carbon fouling plug issue mainly on #4 and a bit on #8. All other plugs look fine. First will fill everyone in on what the engine is.
Block: 408w (351w stroker)
Heads: AFR 220
Intake: Super Vic EFI
Cam: Compcams XFI 248 hr
Ecu: PiMP (microsqirt basically)
I'll stop there for now as the list goes on. Checked compression, all cylinders are the same. Performed cyl. leak down test, was less than 10% leakage. Changed injectors to new Bosch injectors. Put new plugs in it (autolite 3922). Compression ratio on the engine is 10.1:1 so not real high. Running 91 pump gas. Been running the engine for about 2 years with no noticable misfires. Does run rough under 2500 rpm but is believed to be normal characteristics of the large cam. Ecu is batch fire on the injectors so i have a hard time believing that is the issue. Anyone have any similar experiences withthw two rear plugs carbon fouling? Or any other ideas would be nice. Getting to the point to where i may have to pull the head.
Heads: AFR 220
