Interesting. That looks like it's plumbed the opposite way. The steering rack goes into the perpendicular port and the hydroboost is straight through.
I have 18x9's with +24 offset all around. I have the 96+ spindles like you and relocated my fox length control arms inward 0.5".Ok. Just got the email that the wheels I wanted will be back in stock soon. If you remember, I already have two.
I have a pair of 18x9 wheels with +25 offset.
Here’s what will be available.
18x9 +35
18x10 +20
Before you assume I’m getting the 18x10s, don’t. I’m not a fan of the look of staggered dish wheels. I prefer square setups. They did change the offset on the 18x9 wheels thoigh from +25 to +35 I need to see how that will fit on my car and which set would make sense front vs rear. Time to plug in some numbers in offset calculators.
For tire size, probably not going to go too crazy as the tailpipes need to stay. So doesn’t make sense to go 18x10 to stick a 285 tire on it.
I have 96+ spindles up front so I don’t want to poke out too far. Also, with panhard bar in rear the roll center changes, so you actually want to be out a tad to avoid the top of tire rolling into the inner fenders. MM recommends 1/4” spacers but I was hoping to avoid that.
Edit: after playing around with calculators. Looks like I should stick the +35 up front and +25 in the rear if I go with 18x9 all around.
Based on my set up, I think a +35 offset in the front may be too much without spacers - especially if you have coilovers (I can't remember if you do).
If i'm understanding what you are saying, the fluid is feeding directly towards each other, then fighting for space in the T?
If that's the case, couldn't you just swap one line with the one that is coming from the T end?
You can buy the webbing pretty cheap, then pretty much any upholstery shop can restitch them.... Or there's a couple places that do it for $100 per belt mail in services..Also, picked up a set of spare 87-89 belt buckles. Now to dye these black.
You have a NICE lawn.Pulled my #7 and #8 plugs. #7 and 5 others ran about 220 degrees while #8 was near 300.
Does look like that plug was running a tad hotter. I bet that injector isn’t as healthy.
7 on left, 8 on right
This guy came to habg out for a bit while I worked on the car. Just sat in the grass half asleep for 30 min before heading out
Regardless, I can’t try anything until next week. Schools out so taking the kids away for the weekend somewhere fun.
