My 331 Stroker build...your input please
  • Thread starter Thread starter 68keyblr
  • Start date Start date Nov 22, 2006
  • 3
First Prev 3 of 3
89white50
440
central MA
Nov 27, 2006
#41
  • Nov 27, 2006
  • #41
Grn92LX said:
FTI cams are $325 shipped, jay allen cams are just over $400 shipped and cam doctored.
yup, but last time i checked (couple weeks ago) FTI cam was 325 to your door, Jay allen was 280 for the core, and 50 for the came doctor & shipping. basically same price....but those are the two i would trust my cam with for sure.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Nov 27, 2006
#42
  • Nov 27, 2006
  • #42
Jays cams are $369 + shipping + cam doctor.
89white50
440
central MA
Nov 27, 2006
#43
  • Nov 27, 2006
  • #43
only if he uses the steel core, if you ask for the SADI core is 289. almost bud...
Auto Reverse
265
Buffalo, NY
Nov 27, 2006
#44
  • Nov 27, 2006
  • #44
400 RWHP easily...I highly doubt that. My combo with AFR 185's was only 15 RWHP more than the 165's I have now. I kept the 165's becuase I like the way the car felt more, probably due to the higher compression.
retro50 said:
Put on a set of A.F.R. 185's, Comp XE-274 or XE- 282 H.R., Systemmax intake, 75 TB, 30LB Injectors and a 75-80 Mass Air Meter. Should pull over 400 h.p. to the rear tire easily. With all the parts you originally listed maybe 310 at the wheels and that would be stretching it.
A
Allforspeed
264
#45
  • Nov 27, 2006
  • #45
could always build a conservative motor with strong internals and just spray 100shot on it, monster when you want, docile all the rest of the time....
aleborjas
610
#46
  • Nov 28, 2006
  • #46
about haw many RWHP shoul have my combo? signature.
i see that most of you like more 331 than 347 why?
Modular2v
3,222
23
99
oklahoma
Nov 28, 2006
#47
  • Nov 28, 2006
  • #47
its all personal preference. . .i chose 331 because of all the bad things i was hearing about the 347....that and they make very similar numbers
cdog301
236
richmond ,ca
Dec 4, 2006
#48
  • Dec 4, 2006
  • #48
parts
Scorpians are great rockers I initially used "CAT" rocker arms Yeah I know I deserve a kick in the teeth for that dumb ass move!
should see 300 RW @ the dyno later this month!
2KsilverGT
354
Collinsville Va
Dec 4, 2006
#49
  • Dec 4, 2006
  • #49
Gotcha Cdog. I was worried for a moment
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Dec 5, 2006
#50
  • Dec 5, 2006
  • #50
r.barn5.0 said:
the heads, cam and TB you have choosen will choke the
**** out of that engine.
Will serioulsy limit your top end power.
you could get 275rwhp with those parts on 302
get a cam with more durration
get a bigger TB - 70-75mm
get a bigger MAF 76mm min
331 will overload 19's and still push 24's to their limit.
With the right heads,cam and intake a 331 can put down 325+rwhp
AFR 185's would be better if you can afford them
and TFS stg2 cam or CompCams XFI stroker cam
the extra displacement needs a cam that opens soon and closes
later to give it time to fill those extra cubes with the air it wants.
It may choke the engine at high RPM but this is a street engine so it should be strong in the lower range, which I think will..
1) high durration cams are only good when you bump the compression ratio with a stock CR (or near stock) the piston won't have enough time to build pressure and loose a lot of power in the low end which isn't good for the street...
2) 65mm TB is enough imo...
  • 3
First Prev 3 of 3
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
Fox Mass Air Flow 42lb injectors
  • 89wreck
  • Aug 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Scrapla347
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
H
turbo advice
  • hawkinsdrag
  • May 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2025
hoopty5.0
