Thanks for all those comments guys
Yep, I'm in that land down under commonly known as Oz, so time differences don't allow me to be online at the same time,
I have no idea what the HP output is other than it boogies, although as indicated the wideband a/f gauge is showing the 19lb injectors are obviously maxing out at WOT.
But my US net buddy in CA has just taken delivery of some FMS 24lb injectors, calibrated Pro M Maf and also a 93 Cobra X3Z ecu and matching 73mm Maf and they're on there way. After the the 24's are installed I do intend to put it on a dyno out of interest.
However, being in a 4wd I purposely built the engine with low compression for several reasons and high hp was not the main aim etc but its stats are.
5.0 + 020", 8.8 compression, GT40X Turbo Swirl alloy heads with 61cc chambers, all intake exhaust ports matched, custom 1-1/2" headers, E303, 1.7 rollers, 73mm Maf, 70mm TB, 255lph pump, Malpassi FPR, and the injection as shown. I would suspect it should be around the 350fwhp, once the 24's are installed but I could be wrong, so any views would be appreciated.
I may consider replacing the E303 with a more appropriate cam later if the lope etc interferes with 4wd use,
Comments on what would be a good replacement would really be appreciated.
I was interested in this guys comments about the Comp Cams nitrous designed cam used as n/a, particularly the street manners etc.
" if you want awesome low end up to 5800-6k use the comp cams nx264hr cam I am running this cam it is ground to preserve the low - mid end it sounds decent to not to lumpy but not stock either. And if you ever run Spray or super charger it is great fo that too. http://store.summitracing.com/partde...2D35-552-8 This cam has great street manners no surge no drive issues car runs perfect as it did stock.
However, on page 1 of the stats it mentions its not computer controlled compatiable yet if you click on "show all" it says
Cam is designed to be computer-compatible with factory electronic fuel injected vehicles. so I am a tad confused,
Obviously, I want to take advantage of the injection set up but at the same time would prefer good street manners, good mpg but a lope is not a problem
But at the moment with the E303 it does haul to the rev limiter in seconds and so so easy. It also has a bundle of torque and I got a great mpg with my former custom upper manifold and I expect the same with this set up if not better so any comments on the above cam or others would be appreciated.
Its in this,
