My 95 GTS 356 build thread
Mustang95GTS
96
I have been a member off and on here for some time but have not been very active. I wanted to share my build that came together over this summer/fall.
I have a 95 GTS with the current mods:
9.2 Dart Iron Eagle block
Sonny Bryant Billet crank
Carillo billet rods
Diamond forged pistons coated on top and sides
Trick flow 170 heads w/ 205 intake and 1.60 exhaust flowing 305 & 235 @ 600
AFM B451 cam
9.2 super victor intake converted to EFI
75 lb low impedance injectors
AFM Big tube 1 3/4" shorty headers
Vortech T trim w/ 7" lower and 3.33 upper
AFM power pipe.
G-force T-5 w/ super king cobra clutch
FMS 3.55 rears
Awesome build. Jesus dude, what did they do to get a set of TF 170s to flow 305/235. That much port work constitutes sodomy. That's flat out awesome.
Kurt
Dual Walbro's from Glenn's performance sleeper kit
New engine to go in!
Old lower control arms vs new
if I never have to put in control arms again it will be too soon.
Snow performance methanol kit
Steeda caster camber plates
New seats
Engine installed
Here is the dyno graph: tuned by Mike Post
its an edelbrock, which number I am not sure, only 4" tall. Yeah, I took a bunch of pics and figured I would share them. If it took 1 day I would be extremely happy, unfortunately many times in the several months I worked on it I was contemplating rolling it outside and setting it on fire.
can you post a pic or 2 of the clearance over the valve covers?
are they stock height valve covers, or tall?
i have a victor junior efi that i have been dragging my feet on trying to decide which elbow had the best chance of clearing the valve covers and also staying under my hood.
yeah it is tight with a capital T. I had to modify my throttle bracket to adjust upward and have 2 spacers. One is a 1" tall and the other is a 3/8" tall. The valve covers are FMS Tall to clear the studs for the rockers.
good info, thanks.
fyi, i have comp pro magnum rockers which fit under stock height valve covers. going to those might help with your clearance concerns. of course, you have already addressed it, so maybe it's not a concern any more, but it might be useful info in the future ... :shrug:
9.2 ... so that's a 302 block stroked and bored to 356?
302 is a 8.2 deck height block, a 351 is a 9.5 deck height. A 9.2 is between the two of them, used most often as I understand it for nascar type engines. Mine has a 302 main, but it uses a 351 distributor. Kind of a little of both engines.
