This was the first time in months (like 6 mths) that it has rained and the first time since I’ve upgraded my front brakes. Well I almost smashed up my stang because wet rotors suck in my Baer set-up. Just thought you guys should know
cstang68 said:How do they "suck"? Did they lock up too easily? Or did you just find out that everyone around here (SD) randomly brakes in the rain for no apparent reason.
allcarfan said:People do that there too? I think here when a rain drop hits a windshield, it completes a circuit for the brake lights and they light up.
DarkBuddha said:I suspected I might be stirring the pot with my previous post. I have similar feelings about the current big brake phenomenon, that there may actually be such a thing as "too much brake". Apparently I'm not alone.![]()
Route666 said:Brakes don't work when wet, after going through a puddle you should apply a little brake to dry them out, before you need them. Unless you are out driving hard, and the brakes are hot, they're going to need drying before they work well. The effect is amplified with performance brakes since the more aggressive the brakes, the hotter the working temperature of the pad material is, and so being cooled by water makes them less effective in that respect.
mustang70 said:What about water getting into the slots and holes? I know that can lead back to the heat thing since it'll be cooling the rotor off internally, but is there a way that the water can actually build up and make some kind of barrier on the rotor?
