- Mar 11, 2004
- 161
- 0
- 0
Radiator is the source of my coolant leak. Plan to replace with a Fluidine.
Should I get a 160 Deg T-stat or a 180?
Should I continue to use my stock fan, or go with a dual slimline type fan? Can the CCRM be used with aftermarket fans or will I need to wire the new fan to run while the car is on?
I assume this will also mean I need to get an aftermarket trans cooler. Yes?
