  • 1994 - 1995 Specific Tech
New Tweecer Guy
  • Thread starter Thread starter deric89460
  • Start date Start date Mar 7, 2009
D
deric89460
  • Mar 7, 2009
Ok gut I am new to the Tweecer game. I have a 94 mustang with just gears and exhaust. I bought and installed the Tweecer RT I have done some Datalogging already but I'm not sure what to change. The plan is to Drag race the car so I'm looking for some Ideas and timming tunes and anyother tunning that will help. Also if someone could explain what and how to chang the timming tables Thanks
Deric
Mustangless
903
home
Mar 7, 2009
  • Mar 7, 2009
There is a tune on there for aggressive spark tables.
Welcome - [tunexchange: Proudly burning chips and rubber since 2008]
I recommend downloading binary editor. Load that tune and compare it to your stock one. You can see then how spark and fuel is changed.
D
deric89460
  • Mar 7, 2009
I loaded my stock ( I thank anyways) into Cal Edit and look at Functions I don't see a filled out graf just a graf and a box with numbers in it. also you said there a tune for agressive timing tables, where do I find this. Thanks for you help
D
deric89460
  • Mar 7, 2009
correction I had forgot to click on my stock tune so Now I have loaded grafs but where is that timing tune thanks...
Mustangless
903
home
Mar 7, 2009
  • Mar 7, 2009
Go to the website I linked above. You need to download Binary editor (BE)to be able to load the aggressive spark/fuel tune. Wes has a walk-through on the website. It shows how to use the site with BE.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 8, 2009
  • Mar 8, 2009
I'd advise you to master basic operations BEFORE you upload stuff :Word:
You don't wanna slam just anything in there you know nothing about
and
How it might adversely effect your Stang
Just take it easy and focus on the simple stuff at first
Upload your OEM info and save it as such
Then ... make a simple change you can know for certain makes a difference
such as adding 200 rpm to the idle.
Then save the modified file and save it as such
Then upload the modified file and see if your rpm rises
Now ... see if you can upload the OEM file and the idle drops
If so ... You'e mastered
building a file
saving that file
uploading that file
switching between files
Now ... master datalogging
Nothing more than 30 seconds to keep the files nice and small
You will have to build a payload
After the payload is built ... you can do some simple test runs
The idea is to focus on one and only one application at a time
Here is a simple example for you to get the jest of dlogging
Do a cruise at a steady speed of like 30 mph on level ground and
dl for only 30 seconds
Do a second cruise ... exactly the same speed ...
exactly like before on level ground ... for the same 30 second time period
The differene this time is at 15 seconds into the test run go to the floor
with the skinny pedal
You see ... the first file is your baseline or reference point
You then look at the second file and you will find .........
You will be able to see ......
throttle body changes
load changes
rpm changes
loop state changes
spark changes
and much much more
anyway ... I suggest you get familiar with the basics
The only way you are gonna see the possibilities
is to play with it and do lots of basic datalogging to understand what
the pcm is doing with the data the various sensors are sending it
Grady
D
deric89460
  • Mar 11, 2009
Ok maybe I typed the wrong question... does anyone have any input they would like to give for a stock motor with a 5-speed and 3.73s looking for wide open throttle tunes... I have date logged and even played with rpms and fan speed.. just looking for timing ideas and other secrets that other tuners have found...thanks
Zero Signal
2,633
Tucson, AZ
Mar 12, 2009
  • Mar 12, 2009
You can add a few degrees of timing in the upper end, but otherwise don't bother. On the stock motor, you'll hardly get any more power from the stock tune.
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
