Fox Novi 2k Install Checklist
  • Thread starter Thread starter mikerunt
  • Start date Start date Aug 21, 2019
  • 3
First Prev 2 of 3 Next Last
mikerunt
63
11
18
Los Angeles
Aug 23, 2019
#21
  • Aug 23, 2019
  • #21
Also - Anderson Power Pipe
mikerunt said:
Alright - working through the list:
- Novi 2k Tuner Kit
- 340 in tank fuel pump (do I need new fuel lines? I know it was said a fuel pressure regulator is not needed) - any brand recommendations for stock tank compatible one?
- 42lb Injectors and MAF to support
- MSD 6A BTM
- Tune (stock ECU - no Megasquirt)
- boost gauge
- Air / Fuel Ratio gauge
- no to HYD rollers
- no need for beehives
How is that looking?
hotpony
922
12
38
Lee County, KY
Aug 23, 2019
#22
  • Aug 23, 2019
  • #22
I thought you guys in Cali were banned from working on your own cars?
Get the Aeromotive Stealth 340 LPH, replaces your stock in-tank pump, no need for new lines. You will probably be looking at 30# injectors for your setup, 42#'s would be fine but probably not needed. You can always throw the FMU in there for now and run the disc calibrated for whatever injector you get. For example, I have a 347 with Vortech SC-trim and I put the FMU in with a 4:1 disc. I did this so I could drive the car around before I got it tuned, also installed the vortech included MSD 6BTM, which you can dial in ignition retard per /lb of boost. SO since this is a brand new engine and blower, I cranked it all the way up, set base timing at 10 degrees and let her rip. Down the road when I put 500 miles or so on it I'll take it in and have it tuned as I have an Anderson PMS installed to my A9L computer.
I would personally recommend a calibrated MAF for whatever injector you choose, it will 1) allow you to drive the car before getting it tuned and 2) be much easier for the tuner to do his thing. PLUS, you are talking about all this induction through the stock MAF? Can you say restriction? Get a Pro-M or an SCT Big Air (if they still make those), calibrated for the injector you intend to use.
Make sure you put a good set of plugs (gapped to about .035 to .040 or so, you can play with this), also some new wires. Is that Novi 2000 self contained or do you have to punch the oil pan? Be aware that punching the pan while it's installed is pretty risky. I've done it but you have to be very careful and use plenty of grease on the NPT tap, going slowly and removing frequently to clean and reapply grease.
mikerunt
63
11
18
Los Angeles
Aug 23, 2019
#23
  • Aug 23, 2019
  • #23
You’re a legend - thank you.
Any thought on the Anderson Power Pipe?
TOOLOW91
20+ Year Stangneter
8,760
234
S.I.NY
Aug 23, 2019
#24
  • Aug 23, 2019
  • #24
- Novi 2k Tuner Kit
- MSD 6A BTM
- boost gauge
- no to HYD rollers
Don’t need lines at 8 psi . I’d recommend an adjustable fpr ..... most blower or turbo cars they like to set the base at 42 psi . But again just my opinion
TOOLOW91
20+ Year Stangneter
8,760
234
S.I.NY
Aug 23, 2019
#25
  • Aug 23, 2019
  • #25
Power pipe is the way to go ....... you usually see more pressure with it too.
hotpony
922
12
38
Lee County, KY
Aug 24, 2019
#26
  • Aug 24, 2019
  • #26
Powerpipe is ok but know that you will have to cut out the inner fender a bit. Can get sloppy if you dont do it right. You can slice some rubber hose down the middle and use it for a liner. Personally I would just install what the blower comes with if it comes with anything on the tuner kits, you can always do stuff like this later.
TOOLOW91
20+ Year Stangneter
8,760
234
S.I.NY
Aug 24, 2019
#27
  • Aug 24, 2019
  • #27
Plenty of experience with them trust me . No only have I had to cut a hole but later on a scottrod panel hole to pass it through . It’s not bad to open the hole . Painters tape . Mark it . Air saw . No big deal . On a non intercooled kit you’d want the freshest air you can get in the blower too
mikerunt
63
11
18
Los Angeles
Aug 24, 2019
#28
  • Aug 24, 2019
  • #28
I have read that when using a 130amp Alt getting either the Paxton or Novi SC brackets installed can be a pain, especially if you are using this aftermarket 3g bracket:
Mustang Alternator Bracket (79-93) 5.0 - LMR.com
Pick up this direct replacement 5.0 Resto 1979-1993 Mustang 5.0 alternator bracket to get your engine back together!
lmr.com
Does anyone have any experience with this issue or input?
hotpony
922
12
38
Lee County, KY
Aug 24, 2019
#29
  • Aug 24, 2019
  • #29
There is some clearancing you have to do to the bracket. If you have a die grinder you can do this pretty easy. Or a dremel will work but slower. Any reason for the 3G? Big stereo or underdrive pulleys?
mikerunt
63
11
18
Los Angeles
Aug 24, 2019
#30
  • Aug 24, 2019
  • #30
Ive been experiencing low volt at idle on the car. Checked battery and it was still good. Checked all the cables - all good - clean connections. Gauge seems fine. Assuming the stock alt is starting to find so figure while replacing might as well upgrade. Thought about underdrive but most here discouraged.
hotpony
922
12
38
Lee County, KY
Aug 24, 2019
#31
  • Aug 24, 2019
  • #31
What is the voltage at idle?
mikerunt
63
11
18
Los Angeles
Aug 24, 2019
#32
  • Aug 24, 2019
  • #32
It’ll wobble down to 8-10 range, and then once going climbs up a bit.
hotpony
922
12
38
Lee County, KY
Aug 24, 2019
#33
  • Aug 24, 2019
  • #33
Gotcha, 3G is fine but its just extra hassle for not a lot more anything unless you have a need for it. Just throw a reman
In there.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Aug 24, 2019
#34
  • Aug 24, 2019
  • #34
Fyi you can get 3g self exciting alternators for less than 150$... mine is 200amp
mikerunt
63
11
18
Los Angeles
Aug 24, 2019
#35
  • Aug 24, 2019
  • #35
Still needs the larger brackets and mounting though?
mikerunt
63
11
18
Los Angeles
Aug 24, 2019
#36
  • Aug 24, 2019
  • #36
In there.
Yea starting to think about now with the SC path
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Aug 24, 2019
#37
  • Aug 24, 2019
  • #37
I am using the factory bracket, just a little grinding is all it needs
Reactions: hotpony
General karthief
Mod Dude
Aug 25, 2016
28,105
10,717
213
polk county florida
Aug 24, 2019
#38
  • Aug 24, 2019
  • #38
3G Alternator Fox Upgrade
Preface: When the following procedure is complete, the ORANGE/BLACK factory alternator wire WILL NOT BE USED. Whether you cut that connector off or just leave it hanging is up to you (I prefer to just leave it tied up out of the way). Using...
www.stangnet.com
mikerunt
63
11
18
Los Angeles
Aug 24, 2019
#39
  • Aug 24, 2019
  • #39
Any opinion on Paxton novi 2000 or Vortex V2? Tuner kit for both...
1hot87gt
5 Year Member
Mar 17, 2017
445
338
93
New York
Aug 25, 2019
#40
  • Aug 25, 2019
  • #40
I got a Vortech V3 system installed last year. Quiet, self contained oiling system, makes about 10lbs boost which translated to 426 rwhp. That’s about 500 at crank. Very happy with the setup.
  • 3
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
Progress Thread 88 Notched Fox
  • NotchedGarage
  • Jul 15, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2024
Flyboy60
F
J
  • JRC99
  • Apr 19, 2025
JRC99
J
