okay...well I think im gonna go for it AND CHOP MY SPRINGS!
I have eibach pro progressive springs and want the front about 1/2" lower, no lower then that.
Coil overs by the sounds of it arnt the way to go, talked to a few with them and they werent impressed at all. So ill save my $ and put it towards a tuner (tweecer rt).
So how much to take off for 1/2" drop? There 1.5" drop springs as is...so there not stockers.
I would say 1/4 to 1/2 turn of the spring. I think I would mark where the current spring ends as a reference then cut off a 1/4 coil and see where that gets you, then if you want lower do another 1/4 coil...
What scares me about doing this (I am thinking about it for the rear of my vert) is that if you cut too much you can not easily go higher again...
Have you tried removing the isolators yet? They are supposedly worth about 1/4" each...
Chris
the last thing i would do is cut the springs. you will be decreasing the effective load that the springs can handle greatly diminishing the ride quality as well as hurting the car's handling abilities as well. cutting springs is a lose/lose situation performance wise. if you want lower without coilovers, check out the eiback sportlines (lowers the car 2" all around). they gave my car the perfect stance and the handling was pretty good as well. come to think of it, i am about to buy a set of pro-kit springs, so if you want to sell yours to help fund the sportlines, let me know. just so you can see how low it was with the sportlines installed.....
That was me that said you can lower with the steeda bump steer, its not the kit that lowers the car its by removing a spacer thats included in the kit that is supposed to give the drop from what iv been told
I believe you are talking about the Steeda Extended Ball joints. They have a spacer you can remove to lower the spindle which lowers the front a bit more. There was a good tech article on them in 5.0&SF mag. I am sure you could find this on their website if anyone is interested. Bumpsteer kits just improve the tie rod geometry for better on road performance.
SeventyMach1 said:
Sorry to hijack.... but can someone elaborate on this real quick for a suspension noob???
isolators are just the rubber ends on each side of the spring, most say it doesn't mean a thing to remove them... i.e. they don't hear any spring movement or any bad effects
u could do what u want w/ the springs, as said before, if you cut them, make sure you DO NOT heat them at all
i know the big no no is heating the springs but me andmy buddys lowered his t type by heating the springs up and it doesnt ride any stiffer like when we cut springs on his mustangs but you have to be very very carefull to get the car to sit the same on both ends lol i guess we just got lucky.
dan
if cutting springs are so bad why did my FMS C-springs come with instructions on how to cut, where to cut, and how much to cut for additional drop...???
Maybe it is only the FMS springs that have the dead coils that allow this but each of my coils has 3-4 dead coils that do nothing but add height....
So how is this rice/import/bad????
the spring is manufactured with the intention of being able to support a certain weight. anytime you remove a coil or portion of a coil, you effectively reduce the weight that the spring is physically capable of supporting. a side effect of this is a more bouncy, harsh ride which in turn negatively affects handling and will also contribute to premature shock/strut failure. if all you are going for is appearance, by all means save the money and cut the springs, but if increased performance as well as looks is your goal, buying new springs that sit lower is definitely the way to go. just my $.02 for what its worth.
