Pegging the MAF?
Im having a lil debate with someone and was wondering is a Maf's limit based on the injector size its calibrated for or airflow? i saw a thread by Grady earlier discussing a little on this. i can understand the injectors themselves being pegged, but i cant see a Maf pegging unless its flowing its max amount of air. It seems like the bigger the maf used the more air it can flow before allowing itself sensor to be pegged since according to grady's thread about tunning them the voltage doesn't go past 5volts? which is how ive come upon to this conclusion. Im sure Grady will be here to chime in some more,lol
thread im refering too http://forums.stangnet.com/showthread.php?t=701539&highlight=mass+airflow
You have it. ALL the MAF is for is measuring air volume going into the motor. Period. Forgot all that brainwashing we've been put through (I thank the tuning crowd like Grady and Vristang for helping to undo these misconceptions).
The scale is indeed 5 volts. This is done because it's stable. If your battery is half dead or you have voltage fluctuations at idle vs at speed (our volts drop at idle), the 5 volt reference system all but eliminates concerns about fluctuation-induced changes.
Injectors are a different animal. We actually like to see them have a high duty cycle (running near max). If they ran non-stop, that'd be 100% duty cycle. The injectors get constant (accessory) 12 volts and drivers in the puter ground each one when it needs to introduce fuel.
Not to nitpick (but here I go anyway.. LOL!) but the MAF measures air mass - in other words - weight. By doing this atmospheric pressure and temperature changes are automatically compensated.
The other thing is the MAF limit from the factory is actually around 4.7v. A tune can extend that to 5v to allow a little more headroom.
Acutally, 'calibrated' MAFs will peg later if they are calibrated for larger injector sizes. e.g., a MAF calbrated for 24# injectors will peg much sooner than a MAF calibrated for 42# injectors. Since factory MAFs are not calibrated for any injector size that really doesn't apply to them - sort of - because the MAFs on '03-04 Cobras and Gen 2 Lightnings will peg a lot later than one from a 94-95 GT.
Hope this helps.
Don
The "calibrated" MAF idea is only in a global change in the airflow vs voltage out for the sensor. To "calibrate" the MAF really just means to add or subtract voltage at the output. It's all in tricking the computer to calculate the injector PW properly. I say "calibrated" because in reality, it's a hack.
Well :D
Some pretty smart folks have given you good info IMHO :nice:
Did you get the answers you needed to satisfy your concerns :shrug:
Grady
So sounds like we are both right...the said person removed his 75mm for a Pro-M and replaced it for a lightning MAF, i just had disagreement with the needing to rid it as i didn't think the average HCI setup wouldn't come close to pegging it. its calibration was for 19lb injectors tho,but it was for a cobra so the ecu should already be compensating for it. Now im curious if i should buy it but seems like it might be a lil pointless....what do you guys think?
Seems like you might be getting side tracked by physical meter size :shrug:
Sticking with an electronic caled meter such as ProM and the like ...
The meters are setup to measure airflow :Word:
The amount of airflow determines the size inj necessary to feed that airflow.
Focus on the electronics and not the physical size of the meter ;)
Example:
You could have two 80mm ProM meters ........
one with a 19# cal
and
one with a 42# cal
The physical part of each meter is the same
but
The electronics are very different
Lastly ... each meter M U S T work within a 0 to 5.0 volt range
Now you have two choices of application with these meters
1) Use the after market cheat method of matching meter/inj size calibration
2) Use a tuning interface or chip to tell the pcm true airflow & inj size
#2 will usually provide more accurate results ;)
Grady
