Pics of fox bodies with a 99-04 8.8?
Why are you wandering around so much? Stay still for a minute so I can post in your thread.
Most guys switch to fox length axles or just make up for the 3/4" you're talking about by ordering wheels with the appropriate backspacing. I'm sure you can find 1,000 guys on here who have done it.
Reactions: Jason 302
1.5" each side.
The 94-98 axles make the standard 86-98 axle 3/4" wider each side.
The 99-04 housing is wider as well, do it comes out to 1.5" each side or 3" total
Also, keep in mind the LCA bolt hole sizes differ. I believe the newer rears are 16mm bolts while the older are 14mm. I could be wrong about the sizes
Sent from my iPhone 4S using Tapatalk
