I'm in the process of piecing together an HCI, but I don't have the funds to do it right away, so I'm gonna do it in 2 steps. I eventually want a (maybe) ported street heat, twisted wedge heads, and a custom cam. My first step to be completed this fall:
1 - Street Heat intake
2 - 80mm MAF
3 - 3.27 to 4.10 conversion
4 - Dallas Speedcal
5 - 30 lb injectors
Second Step:
5 - 255 fuel pump
6 - FTI Cam
7 - Twisted Wedge Heads
8 - Tweecer
9 - 75 mm TB
I'm looking to be shifting at 6000 grand or so, I want a street car, I don't really plan on taking this to the strip that often. I want the low end, but I want to try to do something a little different then AFR 165s. I DO NOT want a dyno queen.
Now, I know the 30 lb injectors are definately NOT needed at this stage, but I do want them for the future, as I plan on tuning with the stock fuel pressure and don't want to mess with it. I am also toying with the idea of a 75-100 shot, so I don't want to lean out if that ever happens.
My question is, will I be able to do the first step without needing a tune or messing with the timing? I believe that I can but I want to double check. I know the 80mm MAF and 30lbers are much bigger then I need, but I don't think they'll kill me if they are calibrated together.
thanks,
Adam
2 - 80mm MAF
4 - Dallas Speedcal
5 - 30 lb injectors
Second Step:
5 - 255 fuel pump
6 - FTI Cam
8 - Tweecer
9 - 75 mm TB
thanks,
Adam
Don't forget valve springs that FTI will set you up with. My one piece of advice that Grady and keven didn't touch on would be to go a bit more aggressive on the cam. That was one mistake I made when I swapped to an FTI cam from my old TFS 1 cam. I know Grady has said he wishes he went more on the cam. I'm only saying this because I had exactly what you are wanting to do.
