In May I had my car dyno'd on a portable dyno operated by Mid Atlantic Dynosports at the Wildwood Classic Car Show in Wildwood, NJ and got the following numbers :
The only mods to the car at that time were: air silencer removed, K&N panel filter, FMS shorty headers, 2.5" MAC cat pipe, 2.5" Flowmaster Force II exhaust, FMS aluminum driveshaft. Timing was set at 14*, fuel pressure was stock (stock regulator).
Pull #1) 216.5 hp @ 4500 rpm - 282.8 tq @ 3500 rpm
Pull #2) 218.8 hp @ 4500 rpm - 284.6 tp @ 3500 rpm
The Wildwood Car Show is twice a year (May and September), and since M.A.D said they were going to be back in September I thought I could get a nice "before and after" reading knowing I would be performing the following mods over the summer: Densecharger Cold Air Kit w/ K&N cone filter in the fenderwell, 65mm TB, 67mm EGR, Ported Stock Upper, Tmoss Ported Stock Lower, new 19lb injectors, Kirban AFPR, Ported E7's, FMS 1.6 Roller Rockers, Summit Off Road H-Pipe, Magnaflow Exhaust, Performance Distributers "Firepower" Ignition Kit. Timing was set at 14*, at fuel pressure was set at 46 psi (off and plugged).
Upon arrival at the show I found a different company "Axcelerated Motorsports" running the dyno this time.
Pull #1) 218.4 hp @ 4900 rpm - 272.1 tq @ 3600 rpm (46 psi FP)
Pull #2) 221.3 hp @ 5000 rpm - 273.9 tq @ 3700 rpm (47 psi FP)
I am confused about a few things. My air/fuel ratio on the first run went from 13.4 @ 2200 rpm to 11.8 @ 5700 rpm. I could be wrong but isn't that way too rich for an N/A motor? On the next run they had me increase my FP which I did (one pound) and my hp/tq went up albeit slightly, HOWEVER based on the readout, my air/fuel ratio was actually leaner going from 14.2 @ 2200 rpm to 12.4 @ 5400 rpm (he shut it off a little earlier on the 2nd run). I was running the stock fuel pump (I am going to replace it with a 190lph), which I think may have been unable to keep up causing the leaner reading under the higher pressure.
My questions are:
1) Isn't that a/f ratio too rich for an N/A motor?
I've read 13.0 to 13.5 for N/A motors, 12.5 to 11.0 for blowers/nitrous/turbos etc...
2) What variables come in to play when someone dyno's your car?
Can the dyno, operator, software, calibration, affect it?
I mean if that's all the hp/tq I have then so be it, but it would be very surprising to me that the before and after results would be so similar.
My questions are:
