Problem with DSS 306 Long block
  • Thread starter Thread starter my289eatsrice
  • Start date Start date Mar 1, 2006
M
my289eatsrice
121
Woodstock, CT
Mar 1, 2006
  • Mar 1, 2006
I have a problem w/ my DSS 306 Longblock, and want to know if any of you guys are having similar problems with you're setup. Every once in a while, after I've been cruising for a bit, when I slow to a stop the motor will smoke just a little bit, but it is noticeable. I have talked w/ DSS and they told me that the problem is that the motor has poor crankcase ventalation. But wouldnt the PCV system take care of any crankcase ventalation problems(mine works fine)? It doesn;t burn oil(or very little if it does, and its a white/gray smoke). So perhapse it a carbon buildup or something bc of the smoke color? The motor does have about 25k on it, so that may be the problem. I'm just not exactly sure where to go. Thanks.
ninety15.0
1,336
  • Mar 1, 2006
White smoke is generally i sign of coolant burning..ie headgasket issues. Blueish smoke is generally oil cause by blowby or valvetrain issues. and black smoke is generally fuel. I might suggest trying a valve cover breather to see if it clears anything up...what was the condition of the crankcase breather/filter in the lower intake mani. i assume u put a new PCV valve and grommet in there when you did the motor. Maybe give a little more info about your combo that might help too.
M
my289eatsrice
121
Woodstock, CT
Mar 1, 2006
  • Mar 1, 2006
Well, heres my complete set up:
DSS 306 longblock
Trickflow Twisted Wedge heads
T5-Z tranny
GT-40 Intake manifold
65mm Throttle body
Ford motorsport headers
BBK Cold Air intake
MSD 6al ignition
MSD Blaster Coil
Flowmasters
King cobra clutch
Ford racing radiator
Aluminum Driveshaft
3:55 gears
Baer disc brakes
Subframe connectors
caser/camber plates
Koni Yellow shocks/struts
Global bushings
Global Rear control arms
lowering springs
Pro 5.0 shifter
K&N intake
190 lph Fuel pump
FMS 28 spline axles
Fuel pressure regulator
Fuel pressure gauge
Phantom oil temp gauge
Phantom oil pressure gauge
Ford 8mm plug wires
ponys wrapped in 225-50-16 Nitto 450s
Tubo(2-bo)
279
Ft Walton Beach FL.
Mar 10, 2009
  • Mar 10, 2009
Just curious, what cam & injectors?
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
J
  • JRC99
  • Apr 19, 2025
2K
JRC99
J
Need help troubleshooting a possible EEC startup problem
  • JohnW63
  • Jan 9, 2022
  • Fox Engine Swaparoo
  • 5 6 7
16K
Fox Engine Swaparoo Jul 19, 2023
General karthief
