I have a problem w/ my DSS 306 Longblock, and want to know if any of you guys are having similar problems with you're setup. Every once in a while, after I've been cruising for a bit, when I slow to a stop the motor will smoke just a little bit, but it is noticeable. I have talked w/ DSS and they told me that the problem is that the motor has poor crankcase ventalation. But wouldnt the PCV system take care of any crankcase ventalation problems(mine works fine)? It doesn;t burn oil(or very little if it does, and its a white/gray smoke). So perhapse it a carbon buildup or something bc of the smoke color? The motor does have about 25k on it, so that may be the problem. I'm just not exactly sure where to go. Thanks.
