Proform Fan Blade Switch?
Matty469
77
Hawaii
Can Proform and Flex-A-Lite Fan Parts Interchange?
My Proform 15" electric fan came loose the other day and hit into my pullies shredding my blades. Rather than buying another fan for $130+, I looked at what Summit had to offer. Flex-A-Lite makes replacement blades for their 15" electric fan. Both the Flex-A-Lite fan and the Proform fan look identical. Does anyone out there know if the Flex-A-Lite blades will bolt up to the Proform shroud if I were to drill out the rivits and replace with tiny bolts and nutts?
Blades just arrived today. They match up beautifully. Here's the tip of the day- if you have a Proform electric fan and your blades are broken, you can indeed buy the 15" Flex-A-Lite replacement electric fan blade and put them on. $30 from Summit. Good thing to if your happen to find one in the junk yards! They just slide on the fan motor shaft and are retained by a set screw.
