Pros/Cons on buying used Injectors
I need to purchase a full set of 30# Fuel Injectors.
As I look at the cost of New v.s. Used, the difference is huge.
What are the shortcomings/problems to buying used Fuel injectors ?
And, can an injector be tested prior to installation ?
Thanks in advance.
-D
Problems with buying used...You never know what you're getting. They could be brand new take off's or they could be freshly cleaned injectors from the trashcan at a dealership. I would buy from somebody who is reputable on here or various forums for selling good parts or from somebody on E-bay with great feedback.
Can you test them? Yes, you can make sure they work by using a 9V battery and spare pigtail. You can also have them cleaned and flow matched, but by that time you may as well buy a new set. You may also try hitting the junkyard and find a couple sets of injectors. You can usually pick them up pretty cheap. Conveniently they fit easily in pockets or tool boxes too if you buy something else...
Pros: Cheaper and potentially work just fine, just buy from someone credible.
Cons: May not work, but get them flow tested at your local auto parts store, like Napa IIRC.
Yeah, I thought (a couple years back) that a user here said he got his injectors flowtested at his local Napa...some are bigger, some are smaller.
My Napa even has a machine shop that builds engines...:)
