  • 1994 - 1995 Specific Tech
quick pro-m maf?
  • Thread starter Thread starter grngt50
  • Start date Start date Jan 17, 2008
G
grngt50
250
Los Angeles
Jan 17, 2008
  • Jan 17, 2008
Hey guys,
I recently purchased an older pro-m bullet meter. I was told that is the old school 77mm style bullet . Anyhow, the meter is cal'd for a cobra w/ 24 injectors, not a 19lb injector calibration. I have a GT that I'm planning on running with 24lb injectors. Is this meter gonna work for my application, or do you know if they set the meters up differently to deal with the cobra's different pcm.
Thanks,
James
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 17, 2008
  • Jan 17, 2008
grngt50 said:
Hey guys,
Thanks,
James
Hello James
Usually when peeps talk about a bullet meter in the ProM line ............
They are talking about the chrome 75mm meter
Sounds like you are talking about the old Aluminum housing 77mm meter
They were the most accurate meters in their line for many years
That meter is not gonna work for your application
Reason is ... ProM setup that meter based upon the 24# slope
values and transfer curve in the Cobra pcm
Your GT pcm of course has values for 19's and the transfer is
slightly different
Grady
G
grngt50
250
Los Angeles
Jan 18, 2008
  • Jan 18, 2008
darn it........thanks for the info Grady. I should have asked here first before I bought it! The meter looks exactly like the 75 bullet, but the seller insisted it was a 77mm. Is the meter you are referring to the ones that have the stud mounted filters on them? Just curious.
Thanks,
James
G
grngt50
250
Los Angeles
Jan 18, 2008
  • Jan 18, 2008
just an FYI for anyone who may encounter this same issue......I spoke with Chris at Pro-M Racing and was told that a Cobra meter would work on a GT with 24lb injectors so long as the Cobra meter was cal'd for 30lb injectors.
Thanks,
James
95opal
5 Year Member
Nov 16, 2004
449
20
39
Jan 18, 2008
  • Jan 18, 2008
Contact someone over at P-MAS they can more than likely recalibrate it for you.
G
grngt50
250
Los Angeles
Jan 18, 2008
  • Jan 18, 2008
I am already running a granatelli/pro-m 75mm cal'd for 19's. The rep at Pro-M said they would be happy to recalibrate for me. I purchased the Cobra 24lb meter off ebay for much less than the cost of a recalibration in hopes of running it with my new 24lb injectors. Now since my gt40p's are back from the machine shop I'll probably wait to put the injectors on with the new heads and just have a chip burned for the combo.
-James
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
T
Decisions decisions Pro M or Holley Terminator X
  • tank76
  • Dec 21, 2022
  • 2 3 4
22K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 24, 2023
General karthief
Expired WTB 24 lb injectors and MAF meter
  • Vulpes5.0
  • Sep 8, 2021
  • Engine and Power Adder
Engine and Power Adder Apr 1, 2022
Steamfitter
