Rear crankshaft Oil seal sleeve - Info needed
chepsk8
2,203
Easton, PA
My motor in the Cobra has always had a rear oil leak. It is a 1988 5.0, mostly stock. While the motor is out, I pulled the trans & clutch off & pulled the rear seal. VERY worn out. I found some badly worn spots on the seal. The crank has a slight groove in it, I can barely feel it with a fine screwdriver or similar tool. A few have told me to get the sleeve kit for the rear of the crank.
My question is simple - who has done this, did it work, how long did it last, and was it straightforwards to put in? All info really appreciated!
Many Thanks as usual! :SNSign:
Dan
Hey this has ntohign to do with your question im not to sure on the sleve or anything but if i may be able to ask someone i know and get back to you but are you taking teh engine apart compleatly? if so what is the size of the bolt that goes into the camshaft after the timing gear and also the bolts on holding the thrust plate on the camshaft. i baught the my car with the engine out and got new parts but now struggling with lost bolts since i didnt take the engine apart eather so next is hopeing the compartment bolts are all there.
