Rear End upgrade
geostang351
946
Danb., CT
I currently have a 68 coupe wit AOD transmission and rear end with 3.00 open rear. I want to upgrade the rear to a traction loc. My question is should I go to 3.80 gears or 4.11 gears?
THis car has never and probably will never see the track (no tracks near here), just weekend cruising. What are your thoughts and ideas. :SNSign:
I've found 3.55 gears to be in about the right range on my '65 (blown 306 with a T-5). RPM at 75mph (with a 0.83 OD gear in the T-5 - higher than stock and probably higher than your AOD??) is about 2,700RPM and first gear is still usable. A numerically-higher ratio, like the 4.11 gears you're thinking of, would make the RPM rise through first gear so fast that it's hardly worth using it. Hope that helps.
Moving from 3.00 to 3.55 gears seems a waste. I'm not looking for fuel economy just some much needed pep. My AOD 4th gear I believe is somewhere around 0.68.
A lot of the new vehicles have 3.73 gears. They seem to work well in most vehicles that I've driven. I've never driven an older vehicle with an OD so I don't know how they would react to the gears. I would go with the 3.80's if it were me. It would be low enough for good take offs and high enough in the OD for good fuel milage and cruising.
I went 3.80 and auburn pro posi. need to wait till insurance is back on for a test drive. All the late model crowd seems to lean toward 4.11 for the aod unless huffing, then they like less gear. mine will see road trips and if its not enough gear for around town i will add more power.
The 3.55s are about right for the C4/C6/Toploader guys, but for those with overdrive I'd say 3.73 is the lowest you want, and 4.11 is about the limit for "normal" use unless you just wanna bypass 1st a lot. I put 3.89s behind my AOD.
Once thing you did not mention is what size tires you have, they can have a mjor effect on final gear ratio. You might also find this simple chart helpful...http://www.edbert.net/rpm_chart.htm
My tire size is 225 60 15 (tire height I don't know how to figure). Right now I'm 80% leaning toward the 4.11's
Dude, don't go 4.11 in an older pushrod car. That's too much gear for a street car. Those gears are for an overhead cammer like my '99 cobra that likes to wind up. There is a HUGE difference between 3.00 and 3.55, definitely not a waste of time. Go 3.80 absolute max.
I'd say go with either the 3.73 or the 3.90, depending on which way you want to err on.
4.11s get old after awhile (you're not ALWAYS blasting from a stop), and I agree you will find the 3.5s just a little too tall with the overdrive. You may find your cam doesn't like to lug at 2000 RPM on the highway.
You'd be fine w/ 3.80's or better w/ the AOD, I switchfrom 3.55 open to3.80 trak loc and I have a 4sp. My rpms at 60 only went up about 200. I have 25" street tires, I will say if I were not racing the car I probably would have stayed w/ the 3.55's for the street, I did pick up 2/10's w/ added gearing though at the track and really like laying a nice posi patch from time to time on the street. :nice:
Edbert hit the nail on the head! You have to look at the gearing of the whole drivetrain. What is you first gear? What is your tire diameter? THEN figure what RPM you want at your freeway cruise. Only then will you get your rear nend ratio.
Example: I have a T5 with a 3.35 first gear and 3.40 gears. This is about the same as a T5Z with a 2.95 first gear and 3.80 rear end gears. .. Same thing just that 3.40 doesn't sound as cool as 3.80.
Tire size. My 68 with 3.40 gears and 25" tires has MORE RPM's at 75 mph than my 94 with 3.73 gears and 27.5" tall tires.
Most people would automaticly think the other way, but as Edbert said, tire size plays into it. 3.00 to 3.55 doesn't sound like much But.. Check your numbers.
3.00 x first gear = were you are now. 3.55 x first gear is a much bigger number. I don't know what gear you should have, but don't get caught up in the sound of what gear you should have. You'll get the biggest increase in first and second and the least in fourth.
W/the tire size you have I'd say you're in the neighborhood of 25.5" tall tires. You can now use ultrastangs link to help you figure RPM @ 60mph. I usually say 'don't fear the gear', but you want a weekend cruiser so maybe opt for less than the 4.11's, but more than the 3.55's.
