Low-5.0 said:I'm looking to replace my entire front suspension before too long. I was thinking about going with the MM kit, but it's $1700
http://www.maximummotorsports.com/kpkg.asp
Summit has the QA1 kit for around $1000
http://store.summitracing.com/partd...3LB&N=115+4294925130+400026+1008&autoview=sku
The only problem with this kit is the c/c plates look like they're only 3-bolt...
Or I could go with the $700 UPR kit.
http://www.uprproducts.com/shopping/shopexd.asp?id=299
I will need c/c plates($249 from MM), struts(Koni sport's, $166 each @ summit), and probably some bushings and tie rod ends. Overall, the UPR kit looks like it's gonna be the best deal.
Also, what spring size/rate would you all reccommend? I want a good handling car, but mostly set up for drag racing. By good handling, I mean like stock or preferably a little better.
This Month's Mustang/FF Mag has a whold section on the MM grip in the box kit and the install.
RC
