rocker arm ratio
innes
10
i just picked up from the boneyard GT-40 heads off a 97'explorer (not GTP). It looks like the rocker arms on it are 1.5 cause i see the #5 on them.I plan on replaceing them anyway. the question i have is can i put 1.7 on it. i know the 93/94 cobra had these heads w/1.7 rockers.Are the heads completely simaler or are they alittle different and i have to machine them a little
P.S my car is a 88'thunderbird w/a mass air 5.0 HO motor auto
There are lots of differences between the GT40P and the regular old GT40 head. Not just the plug angle (which was done for a more efficient burn to increase power and reduce emissions). The intake runner volumes are different. The exhaust valves are different sizes. Combustion chambers are different sizes, roughly 5 cc if I remember correctly.
BTW: 1.7 rr's would work.
thank you i had a feeling they would fit (1.7) assuming they did not change nothing from when they were on cobras. I guess now i have to figue out valve springs, ill probably use cobra springs since the were 1.7's.And push rods can i use the size on 97'explorer or cobras or 5.0 blocks different year to year.
AND BTW the GT-40P head are better some say 15-20hp more then the gt-40 but cause of the spark plug angle on the you cant get a header on them,thow i heard ford makes a header that will fit.the gt-40p heads can be found on 97 1/4 and up explorer/moutiner's
you can get a header on no problem, same bolt pattern, but most aftermarket shorties have a tube that crosses infront of the #7 plug
