Rod bolt upgrade?
pb_paulie_b
894
Chaptico, Maryland
I've got my all forged stroker assembly [Eagle] it is said it's good for 800+ hp and more with a rod bolt upgrade. I'm eventually going to take it up to around 750 and 7000 rpms. Should I do this upgrade with ARP bolts or would I be throwing away my money?
Well, you have to make up your mind now what your limits will be with the engine. If 7000rpm and 750 hp is it, and you're sure about that. I think you'll be fine without the upgrade. If you're unsure, then spend the money and have them done so you won't be pulling everything out and apart later.
Chris
