Scum Tech Question
SCORPION
386
Seaford, DE
Hey guys.....need your input on this upcoming project:
stock block - bored 30 over and cleaned up
DSS 306 Rebuild kit with their Pro-Lite pistons
I need some help on the best cam for emissions legal HP, heads, intake, and if I should think about a new crank.
I am asking you guys because you know the car better than all those that are floating in this creation called cyberspace.
THANKS ALL :flag:
power adders will have to wait awhile....the bottom end has around 185k on her. is there anything I need to be concerned with or replace down there?
Fred...how does the HP to EPA equation stack up with those 2 cams?
Jason,
both will pass smog! I have an E-303 with my set up now. I run 8psi of boost and I have 176,00 on my bottom end :D
Fred :flag:
Hey Jason
What's new?
On the bottom end I would install a girdle to reinforce the bottom end. If you decide to go with a blower, I would have them intall forged rods, the pistons sound good but as far as the cam, you can install a LUNATI 51014, it has better duration and it is a dual pattern cam(compared to the FRPP E and F cams). The intake is .500" lift and exhaust at .510" lift. As far as intake and heads, IMO the Holley systemax is a great intake, especially if your going to put a blower and as far as the heads, the AFR 165, 185 are a good choice, the Trick Flow heads are also a good choice. Another good performance upgrade would be gears, 3.73 will give you nice performance..........and don't forget the tranny with all that power, the tranny will need some attention. Subframe connectors would be a + + to stiffen the car.
Good Luck and you can always count on us S.C.U.M's for some input.
When is baby coming? Say hello to your lovely wife.
Pierre
M8KMDAY said:
Hey Jason
What's new?
On the bottom end I would install a girdle to reinforce the bottom end. If you decide to go with a blower, I would have them intall forged rods, the pistons sound good but as far as the cam, you can install a LUNATI 51040, it has better duration and it is a dual pattern cam(compared to the FRPP E and F cams). The intake is .500" lift and exhaust at .510" lift. As far as intake and heads, IMO the Holley systemax is a great intake, especially if your going to put a blower and as far as the heads, the AFR 165, 185 are a good choice, the Trick Flow heads are also a good choice. Another good performance upgrade would be gears, 3.73 will give you nice performance..........and don't forget the tranny with all that power, the tranny will need some attention. Subframe connectors would be a + + to stiffen the car.
Pierre
Good stuff Pierre,
are you going to the Q tonite ?
Fred :flag:
With all the choices out there these days, it's hard to go wrong with any of the brand name head/intake/equip companies. The bigger question is whether you'll go blown down the road or not. I ran my rebuilt 306 for a year N/A, but always planned on a SC so did the following up front:
Used ARP head & main studs instead of bolts for added sealing
30# injectors vs 24#
ProM77 mass air meter vs a smaller C&L meter
Crower blower cam w/218(I)/226(E) dur., 510/510 lift and 114LSA. Blower combo's like a little more exhaust duration and LSA. Plus a wider LSA will help it pass smog. The Lunati #51014 has very similar specs, but with a little tighter (112) LSA. This is the cam that comes with the Holley Systemax II package of heads, cam, and intake at a good price ($2,000).
Canton 7qt oil pan for added capacity
Your crank should be fine. Just get it checked and polished. I used ported Edelbrock 6037 heads, but AFR, Twisted Wedge,and Holley are probably better in terms of stock flow out of the box. I also used a ported Cobra intake, but only because the Edelbrock intakes were on national back order at the time. The Holley intake is probably better still. And, as Pierre pointed out, subframe connectors are a must with the added power. It's also a good time to upgrade the clutch/PP combo and rear end gears if you haven't done so already (3.55's or better).
I guess the main point is that if you plan ahead you won't have to buy the same part twice down the road. Good luck and let us know how it turns out. :)
thanks all!!!!
the tranny is out of a 93 cobra with titanium gears along with a centreforce dual friction clutch. 3.55s will be the most likely candidate for the rear end due to top speed limit of 55mph here and short driving distance to work. I do plan on putting a blower on her at somepoint down the road, my goal is to have the strongest, most durable N/A block/setup as possible so that if I have 5000+ miles on her before I can blow her, I won't have to worry about the integrity of my setup.
The baby is due in October. Its going to be a boy and we plan on naming him Logan William Lee. Kary has had a real good pregnancy so far (knock on wood) and the baby is growing right on schedule.
Again....thanx for the input and stay in touch.
VIVA LA SCUM!!!!
