OK ... Where to start ... Its gonna be kinda long
Here we go
Some basic info to get you started
91LX_5L said:
Well honestly 90% of the stuff you guys said means nothing to me I dont get it!
Nether did I when I got started
You could visit the Tweecer site and go all the way back in those old threads and spend some time there. Thats when lots of peeps were getting their self tuning feet wet and you can pick up info more easily as you will be able to relate better.
btw ... don't waste time on fox threads ... 94-95 only at first
Im not that good with these tables or any of these meanings,
Nobody is when they first get started but you pick it up as you go.
im not a super tecnical guy so I get confuised with this realy easy so please bear with me. I will learn as I go thats why I wanna start with the basics.
Lets start over:
1994 Mustang GT
Ajustable kirban fuel pressure regulator (bumped up pressure)
Stock Computer & Stock 19# Injectors
Worlds Windsor Jr Heads (similar to GT40)
e303 Cam
Cobra Intake
70mm tb
CAI
Full exhaust and shorty headers
Underdrive Pulleys
You don't have to be super technical to self tune because if some
Hick in Texas with a Laptop (ME) can do it ... ANYBODY ... can do it
BUT
You gotta invest a bit of time/effort to pick up the basics. That will enable yourself to understand how the pcm goes about doing its thing.
Here is another way to put it ... I hope it makes more sense ...
How does one go about improving upon something (pcm) if they don't understand how it works in the first place
You don't have to know EVERYTHING about how the pcm works
BUT
You DO have to have a general or basic idea about how it operates.
Since you still got the stock maf ... that will make things much easier.
Ok now I dropped my timing back down to 10*. I want to bump it back up to 14* using the tweecer. I am a total newbie to this and none of these tables or anything mean much to me, im not too good with technical stuff.
So I want to bump up my timing, can someone please explain step by step how to do this? Also are there any other things I should adjust that are super easy as well, what should I adjust them to and how and what do they do???
Thanks a lot in advace, I just want to do some super easy tweecing and mabye ill feel a bit more comfortable with the software and can do some more complecated things after.
THANKS
In order to make all this happen you are gonna have to deal with ...
load and how it effects the various spark tables
total amount of spark
advance rate of spark
tip in spark scalar
data logging in CalCon
It is not as bad as it first looks
btw ... It won't be the SOFTWARE that will be the challenge
Its gonna be WHY would you want to change something in the pcm
based upon
WHAT the car is the car telling you by the data in the d logs
Anyway ......
Since you said you wanted to start with the basics
Here they are
Get your data logging up and working and drive around while capturing data to your hard drive so you can study it to see what is going on during different driving conditions.
Use the data in the log to observe the following
spark
load
lambse
kamrf
closed loop driving conditions
open loop droving conditions
That will really give you something to relate to as far as what the load thing is all about with the 94-95 Stangs
Here is another tip to help you get a quick start ........
Jason has some good info on his site and I got a bit of basic stuff on mine as well.
You'll be fine
You learn all this self tuning stuff
JUST LIKE
You eat that big old Elephant
One bite at a time
Slow down a bit
It all can't be learned in a day or two
Just have some fun with this stuff
Grady
