Sn95.0 Wiring Harness Help
Hey man ! Nice crazy build you've got there.
First, ditch the 95 computer....its the most temperamental one to choose from they don't like modifications. The easiest computers are from 89- 93. The emissions stuff can all go. The 94-95 actually do some funky stuff with the Ignition module on the distributor, that tfi module isn't compatible with earlier computers. Pins 11, 27, 31, 32, 33, 34, 42, 48, 54, 55 and related wiring could all be deleted and the car would run decent. 27 and 33 are for EGR and I see no real reason to delete them. Without being there its hard to tell what you can delete entirely. The wires running to and from the components listed can be deleted. Pins 8 and 22 are where my knowledge stops. 8 checks for a signal from the fuel pump relay and 22 is the ground for the FP relay. I don't know if the computer needs that signal to fire the injectors in a 95.
A stand alone would be a lot easier for what you're doing....but looking at your build it doesn't seem like you're the type to take the easy way out. I use mspnp2 for my car. I have some more detailed info...I'll try and post it tomorrow.
Sadly you are very right ahah, the easy way seems boring :P and expensive ahah
as for them being tempermental, i wouldnt know yet!
the bigger issue im having now, is now that ive unwrapped the looms, im curious to what keeps the voltage for the maf and the IAT, is it the ecu or are there a set of resistors somewhere i need to keep intact, as i havent seen any just yet
SIDE QUESTION!!! WHICH IS FUEL INLET??? OR DOES IT MATTER
This is pretty standard advice from Fox folks, but it's not universally agreed upon nor universally applicable. If you're intending to do any substantial modification or tuning - which requires a proper tune anyways, stick with the far more powerful 95 computer. Any tuner (professional or self-taught) worth their salt can easily tune the 95 computer. If you want something that will limp-along with your mild modifications, then the A9L might be right for you, if you don't mind spending $ to downgrade.
I'm a little old school when it comes to T4M0....I have very little experience with them. The factory tune in them changed to be more emissions friendly. Without big changes from stock it can perform well.
@jozsefsz You are correct on my view of the T4M0. I assumed that the OP would be upgrading a lot. When tuned correctly the stock ecu is more powerful than the latter, agreed. The A9L has more support and is easier to tune...but less powerful. Guess they're both over 20yrs old. The best would be stand alone....but I respect the OPs pockets. lol
The line on the top should be the return line...the one on the bottom should be the feed.
I'm a huge QH fan. I run standalone now but Willie Lynch is the man at Dirtydirtyracing.com...he's got anything you'd need including awesome tunes.
What dash cluster do you intend to use?
Realistically, the car can be tuned to perfection with either EEC. The 95 EEC is faster. That aside, there may also be issues with interfacing with a gauge cluster so that both are happy.
Reactions: RaggedGT
Awesome info guys!!!!
I'm running into a slew of problems back to back ahah
seems almost like somethings not quite right with internals :/ after sitting the better part of 6 months it almost seems like the starter is hydrolocking the engine.
the starter sounds like its full of rocks when turning over the engine, and after an almost 360* it seems to freeze and the starter binds up and just makes the typical im using a lot of power but met my match humm.
After throwing a 15/16 on the crank its a bear to turn and then frees up, for as many times as id like to manually rotate it, seems odd any insight??
Gauges
BMW Speedo
BMW Fuel
Ebay RPM Gauge
Autometer Oil Pressure
Autometer Water Temp
AEM Wideband
AEM Boost Gauge
all yet to be wired in until the it cracks to life for a split second, i have a fear ill be pulling it out to be rebuilding if i cannot address the issue with a new starter and a new set of grounds.
SO, anyone have any leads on the ecu power? anything aside from the Keep Alive? and is there anyway to tell if the ecu is powered up? i feel like an idiot, im fairly certain ive spun and tumbled it looking for an LED hahaha
The following are diagrams courtesy of Tmoss & Stang&2birds
94-95 5.0 Mustang ECC
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
TFI module wiring for 94-95 Mustang GT
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-IgnitionControlModule.gif
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
Engine mounted fuel injector harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangEngineHarness.gif
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/TPS_IAB_Pic.jpg
Starter circuit
http://forums.stangnet.com/attachment.php?attachmentid=21328&d=1080916057
Alternator diagram for 94-95 Mustangs.
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-Alt.gif
