speedometer/speed sensor problem
dsj2086
I have a 95 mustang v6 and for as long as i've owned it the speedometer has not worked. I've replaced the guage cluster once as well as the speed sensor and neither fixed the problem. I did an electrical test on the speed sensor and it seems to be working fine. I'm considering buying another cluster as it was used and could also be bad. But I was wondering if anyone had a picture or could tell me how to test the electrical on the other end near or at the computer. Any advice or suggestions would be greatly appreciated :)
MustangLX-5.0
858
Lehigh Acres Fla.
If the cluster was used, what year did you get it out of specifically? This is important. Even though SN-95's have nearly identical looking gauge clusters, there are many electrical differences. An example of this, you cannot use a gauge cluster from a GT in a V6 model without doing a few modifications. Does the new cluster read 120MPH or 150 MPH? If it's 150, then you have one from a GT...or at least the 94-95 GT. You CAN use the Speedo from the GT cluster... just carefully unplyg it from the PCB socket and swap it out on to your own. It will work fine that way.
There's also a chance that the speedo isn't your problem. Does anything else appear to not be working ? Lights...gauges door chime? Theres a fuse that controls some of the gauges and EEC relays... etc.
