springs or full length SFCs?
40th GT
916
Lawrenceville, GA
Which would make a bigger improvement? I'm thinking about doing the fox body spring thing or get MM full-length SFCs. I can't do both at the same time right now. What all is involved when I'm cutting/changing springs? I hope this is something I can do by myself.
are fox springs progressive or linear, I dont think progressive springs should be cut, and you might want to do you shocks/struts and cc plates at the same time as springs(if your car is an 04 you can probably use your existing shocks b/c theyre new). Go with the subframes since its cheaper and doesnt require spending extra cash.
The reason I wouldn't do springs for a while is that I don't see the straight line performance really suffering from the current springs.
Now put in some cut up fox body springs, and shave a tenth off your qtr mile time...by gaining that tenth you are sacrificing overall handling characteristics.
For that reason, wait on the springs- go with the SFC.
