Im running a qa1 k member with stock a arms clearanced to fit. When my CC plates are as far as they will physically go im at about 2 degrees negative camber still.. in order to get another degree or so i was considering camber bolts... Anyone using them?
Also does anyone run fox arms instead because they are 1'' shorter??? Id assume id need a new sway bar from a fox as well.. im assuming by doing this id loose lock to lock clearance on my inner fenders.
What would be the better way to go???
