T/W HEADS GT 40 INTAKE READY TO GO ON NEED ADVICE
rod196202
44
NEW HEADS AND USED INTAKE SETTING IN MY SHOP READY TO IN STALL BUT WANT EVERYTHING I NEED FIRST BLOCK IS STOCK 80,000 MILES GETTING A CUSTOM CAM BUT NEED SOME INFO FIRST DO I USE STOCK INJECTORS OR UPGRADE? FULE PUMP? MAS AIR? ANYTHING IM FOR GETTING??? SHOULD I FRESHIN UP BLOCK? SHOULD I LET THEM PICK MY CAM THANKS FOR ANY HELP
Measure your pushrods to get the correct wear pattern on top the stems. I've got 1.6 Comp Pro Magnum RR's and they're the ****nit. Use 24 or 30lb injectors, 19's are too small. If you get a custom cam you'll have to check piston to valve clearance.
