TB 70mm vs 75mm?
citmov
632
12
49
Chi-town
Anyone running a 70mm or 75 mm TB? I'm about to swap out my intake and wondering what would be better or if there's really a big difference b/t the 70 and 75. Any thoughts?
My set up is pretty stock.
-Intake will be either Cobra or GT Tubular
-E7 heads w/5 angle valve job on the heads & bowl blend v-job into the ports
What do you guys think?
From a performance standpoint, there is practically no such thing as "too much" throttle body. However, I will say that the GT-40 style intakes have a 68-70mm opening on them, so bolting up a 70mm TB would take very little grinding to port match, if any. A 75mm, on the other hand, will require some work with the Dremel tool to match it up.
FWIW, I had a 70mm TB on my car with the stock intake (port matched) and stock heads for years.
