I just installed term x on my 302 hci/v3 . Runs great under load. When in light throttle or at idle it seems to be loading up rich with fuel. I attached a zipped data log where at idle in neutral and randomly shuts off. (Around 45 seconds) Struggling to find the issue. Raw fuel smell from tail pipes thinking why it's going rich. It will start up again after 15 seconds of sitting.
The ve learn fuel table wanted to pull 30% fuel in the idle kpa range (13-15 inHG) so I transfered the learn table to the base table. Helped a little.
I have the green top 42lb lightning injectors in it. The holley doesn't have that injector in their database. I tried the 30 and the 47 lb ford injector drop down..
