liljoe07
5 Year Member
It's easy to check. You can simply pull the coil wire from the cap, stick a spark plug in it. Loosen the distributor, and rotate the distributor back and forth. With the spark plug close to the coil post on the cap, it should spark when the pick up passes by one of the reluctor vanes.
One could assume that since the car runs, the pickup is fine for the most part. But I have read from an article about the design of the TFI, that the TFI is supposed to be able to generate it's own PIP signal should the pickup fail. I have never seen it happen though. Most the ones I have seen were complete loss of spark when they failed. And some had erratic PIP signals.
