Ok guyz...I am running a comp cams extreme energy cam with my current setup.
Specs are 218intake/224exhaust @.050" lift, .544" max valve lift on both lobes and 112 lsa.
And the motor is a DSS331 w/ AFR 185's (with spring upgrade) and a performer rpm II intake. I obviously have all the supporting mods.
I put this cam in when I did the stroker (2 yrs ago) because I had to pass emissions. Now the car is exempt and so I was thinking about going with a larger (more duration) custom grind from ED and getting the car tuned (finally after 2yrs. on the stock cpu). Currently the car makes 330 rwhp at 5200 rpm. I believe theres a lot more in it, but I could be wrong....
Also I called a local shop and was quoted about $400 to swap just the cam + the price of the cam $350 + the chip and dyno tune $500 = $1250.
Do you guyz think $400 is reasonable for a cam swap...also I am considering doing it myself but I am lazy. Is there a good write up anywhere.
FInally, do you guyz think its worth it to buy a new cam and spend a bunch of time or money installing it or should I keep the current cam, get a tune and be done with it. This will be the last possible mod for this motor. Then I am just gonna maintain it and keep running it, hopefully for a long time.
Sorry to be so long..if you have opinions/answers to any of the questions above feel free to chime in.
