it means you have to wait 16 minutes before you can start it.
What does it mean when this happens?
A few things, the main concern is the MAT or IAT sensor heat soaks with a lack of air transfer around it... that is until the engine is pumping again, this causes the MAT correction [remember SD uses MAT temps in the air density equation] to become lean on HOT start. To properly correct this without altering the running fuel correction [ this means we do NOT want to alter the MAT correction table after we are done tuning as this will require further fuel trim in the main table] we will go in and add fuel in a percentage to offset the sensor soak for the first minute of startup. We will do this in the ASE and ASE taper tables [after start enrichment and taper 'how long the ase stays in effect'] properly set the engine will not experience any lean condition at startup, as a driver you would not even notice it could be an issue.
The only way I was able to fight this was to alter the mat temp table. Didn’t take much, just a bit of adjustmentA few things, the main concern is the MAT or IAT sensor heat soaks with a lack of air transfer around it... that is until the engine is pumping again, this causes the MAT correction [remember SD uses MAT temps in the air density equation] to become lean on HOT start. To properly correct this without altering the running fuel correction [ this means we do NOT want to alter the MAT correction table after we are done tuning as this will require further fuel trim in the main table] we will go in and add fuel in a percentage to offset the sensor soak for the first minute of startup. We will do this in the ASE and ASE taper tables [after start enrichment and taper 'how long the ase stays in effect'] properly set the engine will not experience any lean condition at startup, as a driver you would not even notice it could be an issue.
Altering the mat air density curve is sometimes a necessary evil... different intake, sensor arrangements may even need different curves, especially if the sensor placement was altered.The only way I was able to fight this was to alter the mat temp table. Didn’t take much, just a bit of adjustment
I ended up changing over to a gm intake air temp sensor as well, and moved the sensor away from the #5 runner and into the upper intake plenum.
