Using stock rockers on GT40P?
tbud
Also what about stock lifters and pushrods from stock heads from 1988 GT. Bottom end is all stock. Please if I cant reuse the stock stuff what you reccomend?
Thanks
Stock stuff should work unless the heads have been milled then you might run into issues. I am using the stock lifters and pushrods on my 93. I upgraded to a set of 1.6 scorpion roller rockers instead of the stockers.
I have Thumpers (Ported E-7's) and I used the stock lifters and pushrods.I put 1.7 RR's on because Im using the stock cam. Im using Crane Roller rockers,they are actually the ones Cobra's use!!
