Well, yes and no. Drum brakes are crappy whether on a V8 or 6 cylinder car. From 67 up, the only thing different in the suspension is from the spindles out which makes it a five lug. Any old springs need to be replaced, so just replace them with slightly stiffer springs. Bigger sway bar helps.
I did the swap on a 67 and drove it with no changes for years. The brakes sucked and it leaned alot in corners so it was no performance ride for sure. As time and money allowed, I upgraded to V8 spindles (junkyard), 620 spings, roller perches, aftermarket upper control arms,etc...
If it is a pre-67 car, there are some dangers in weaker frt. end parts.
