Vortech Problem
Hi all,
I'm having a problem with my car since i have installed a new Vortech V3 setup. I brought it to get dynoed after it was put on and only made 15 more horsepower than i did before(went from 265 to 280) and I should be making much more than that. it makes 6 lbs of boost. It runs well (doesn't cut up and the a/f is perfect). Any ideas?
Setup is as follows:
Vortech V3-SC
42lb injectors
90mm Lightning MAF
SCT 4 Bank
UPR Boost pipe
Autolite 103's gapped to .035
BBK 255 in tank
Thanks in advance for any suggestions.
Jim
Sounds like a trans/rear end problem. If you're sure the motor is making the power and the tune is right, there's obviously some reason it's not making it to the ground
That was my next thought. if its making boost then it could be a clutch or converter issue. by the way what does your A/F look like under boost?
Either way it goes you should see. roughly 10WHP per 1# boost through a vortech. are you sure the parking break was'nt still set?:rlaugh: just playin
